Broadband & Landline
Post here to ask/answer questions around home broadband and landline
Forum Posts
Google Pixel 8 WiFi issues?
We're aware of reports from Google Pixel 8 users who are having difficulties connecting their phones to the new Smart Hub 7 Plus. When trying to connect your Pixel 8 to the hub's WiFi, you may find that it fails to connect at all, or connects very br...
James_B by EE Community Manager
  • 2371 Views
  • 12 replies
  • 12 Helpful
Need Help with Your Home Broadband Speed or Connection?
To effectively help you with any Broadband speed or connection issues we would need to see some hard data about your line after carrying out a few short tests for starters, which will enable us to diagnose the problem and advise you further.   Using ...
XRaySpeX by EE Community Star
  • 47235 Views
  • 2 replies
  • 10 Helpful
Changing Your WiFi Password on a Smart Hub
You may have seen in the News that some ISPs have had a security breach whereby their users' routers WiFi passwords have been hacked. You might want to change the WiFi password of your EE Smart Hub router in case a similar attack is made against EE's...
  • 92244 Views
  • 11 replies
  • 12 Helpful
Router location is at back of house
I have EE part-fibre but want to switch to full fibre which is available to me. My router is at the back of  my house. I have read horror stories about OR contractors not wanting to run cable around a property, especially if sharp corners are involve...
Nucky by Investigator
  • 90 Views
  • 6 replies
  • 0 Helpful
EE WiFi7 Router Pro device power usage in compatible mode
I noticed that whenever I was using compatible mode with battery powered devices the batteries ran out quicker than when using other WiFi access points. I really noticed this with the Ring doorbell when I changed its WiFi from my old BT Hub to the Ro...
tnj by Skilled Contributor
  • 45 Views
  • 1 replies
  • 1 Helpful
Replying to an email
I am replying to an email received from Shelly on Sat 4/4/26 regarding my landline handsets as shown below: I can confirm that I managed to make the original handsets work properly by pairing them to the hub. I cancelled the order for the new handset...
Ps5
Hello,I have just upgraded to the smart hub pro and i can't seem to connect my PS5, it is showing the slow signal fault, all other devices are fine.Any ideas?Cheers
Resolved! Strange PS5 Pro download issue - EE 900 Core
Hello a strange one indeed,I'm on EE's 900 core full fibre, using the Smart Hub 7 Plus SH35A with the latest firmware (confirmed by a quick Google search).The speeds and pings are fine (confirmed on other devices and on my PS5 Pro via the connection ...
MarkCleg by Investigator
  • 1357 Views
  • 23 replies
  • 3 Helpful
Resolved! Buffering
Anybody having slow speeds and buffering at peak ish times like 5 to 8 pm , or after 10 pm , or midday ? EE don’t seem bothered and also I’d like to know how to switch BB provider as my contract ends soon .
DandL1 by Contributor
  • 132 Views
  • 4 replies
  • 0 Helpful
Resolved! New EE router blocking Home Assistant
Hello, I have just upgraded to the new EE wifi 7 hub and extender with a 1.6gbps connection. Set up was easy and speeds seem good and fairly consistent.,The problem i am having is that i cannot connect to home assistant via my PC when connected to EE...
Resolved! How to send a link to invite a guest to use my Wifi
I have a new Smart hub router, so the way in which visitors could potentially use my Wifi has changed.   I had to install the EE app into my phone (ok), then set up a guest name for WiFi, and a guest password (ok).   But I gather that I need to 'invi...
Thelms1 by Explorer
  • 142 Views
  • 5 replies
  • 6 Helpful
