Broadband & Landline
Post here to ask/answer questions around home broadband and landline
Forum Posts
Need Help with Your Home Broadband Speed or Connection?
To effectively help you with any Broadband speed or connection issues we would need to see some hard data about your line after carrying out a few short tests for starters, which will enable us to diagnose the problem and advise you further.   Using ...
XRaySpeX by EE Community Star
  • 44747 Views
  • 2 replies
  • 10 Helpful
Changing Your WiFi Password on a Smart Hub
You may have seen in the News that some ISPs have had a security breach whereby their users' routers WiFi passwords have been hacked. You might want to change the WiFi password of your EE Smart Hub router in case a similar attack is made against EE's...
  • 86934 Views
  • 11 replies
  • 12 Helpful
Smart Hub Plus SH31B Router Firmware changelog
Hi,Just thought it might be worth putting up a list of all the firmware rollouts for the Smart Hub Plus SH31B Router that have happened in the past year or so to see if this adds/removes functionality or fixes/introduces any bugs to the routers.Last ...
monitorcurve by Established Contributor
  • 3449 Views
  • 15 replies
  • 18 Helpful
Smart hub plus port forwarding help.
Hi,So I have two gaming consoles. Series X and PS5. In call of duty: My PS5 has a moderate Nat type because my series x uses port 3074 for Xbox live.i change my series x to use a different port for Xbox live (on its advanced settings). I restarted my...
DraigSW1 by Explorer
  • 13 Views
  • 0 replies
  • 0 Helpful
EE App will not link to my hub/router
No matter whether I try to connect manually or scan the QR code, my EE App refuses to link with router.  Always get the message that my router and mobile phone must be connected to the same wifi net work. THEY ARE!!!I urgently need to change my wifi ...
Chailey by Visitor
  • 31 Views
  • 1 replies
  • 0 Helpful
Xbox connection
Hi. So ive had the 900 for about 3 months ive got the router in the living room and the xbox console on floor 3. I have a booster next to the xbox with a ethernet cable connected. I've never had one issue bet recently ive been experiencing connection...
Tomf831 by Visitor
  • 24 Views
  • 0 replies
  • 0 Helpful
Broadband still down
1 week now without any Internet connection 3 separate times engineers have come out and yet still not been fixed. Smart hub still yellow light. Had no updates when it will be fixed just been left in the dark as usual
Eeisbad21 by Investigator
  • 77 Views
  • 6 replies
  • 1 Helpful
