linestats on ee hub 3
davidwf15
is there any way of seeing the detailed line stats (SNR, attenuation etc) on a brand new smart hub 3?
6 REPLIES 6
None at all!
There is no such Smart Hub 3 with EE. I'll assume you mean a Smart Hub Plus (model SH31B or SH32B).
The last EE router to display such stats was the Smart Hub Plus (model SH30A) or maybe only its predecessor Smart Hub (2023) (model SH20A) .
davidwf15
this is my hub.....
all it will display is this
whereas the previous BT one showed the SNR and attenuation amongst others
Have you looked at the Advanced Settings > Technical Log > Information page for them?
davidwf15
thank you.... thats where I found the attached speeds etc....but no SNR or line attenuation etc...
@davidwf15 There is really NO other way off saying apart from what @XRaySpeX pointed out to you earlier in the post.
With that EE Smarthub+ there is NO values that you will find anywhere, even if you keep searching. EE May/may NOT ever include them but it would involve a FW update and a GUI update so highly unlikely ever to happen!
Oh, OK. Then it must be only from the Smart Hub (2023) (model SH20A)  that you can get proper DSL router stats.
