23-06-2025 09:43 AM
How do I turn off voice mail service without going crazy in the meantime?
23-06-2025 12:31 PM
@kruger1 Since you have not looked at any other post's EE have now since stated VOICEMAIL will NO longer EVER be allowed to be turned OFF!
23-06-2025 01:48 PM
You can't turn landline 1571 VM service OFF but when you dial 1571 under Personal Options (2) > Calling Options (3) > Ring Period (2) there is an option to set the ring period to Short (4 rings), Medium (7 rings) or Long (10 rings) to give time for your own answering machine to pick it up.
23-06-2025 05:27 PM - edited 23-06-2025 05:32 PM
@XRaySpeX Just a heads up and do not know if it was a particular phone answering machine, but got the OP to adjust his answer machine and best was 6 rings before EE voicemail kicked in, so either a screwball machine or the extended service was not going out to the full 10, know you may miss 1st or 2nd for silent ring but 6 did seem well low. Post is below!
Solved: Landline base unit answer phone vs. 1571 conflict - The EE Community
