Smart hub plus port forwarding help.
DraigSW1
So I have two gaming consoles. Series X and PS5. In call of duty: My PS5 has a moderate Nat type because my series x uses port 3074 for Xbox live.
i change my series x to use a different port for Xbox live (on its advanced settings). I restarted my router and ps5 is still moderate so I’m guessing port forwarding is the way forward?
How safe is it doing it on smart hub plus? And how do I do it.
I did it once before on smart hub 2 when with BT but I had a tech help me do it.
Christopher_G
Hi @DraigSW1
Welcome to the community.
It's safe to do, if done correctly. Have you tried following the steps on our Port Forwarding: Access an External Network or Server from Home help page?
Hi
I did read this page and attempted it.
So my router doesn’t lock its internal ip addresses to devices, so I selected for ps5 to always use the same one.
I set to use UDP/TCP and I put the start and end of the both internal and external 3074. I called the rule call of duty.
Now I have an open Nat type in call of duty.
Is this the right way/safe way to do it?
P.S that’s the only port opened. I haven’t done any other port forwarding.
That should work if 3074 is the right port for PS5. Googling it tells me that's for XBox.
