Compatible Printer
Spyboy
Along with it seems, many users I have great difficulty setting my HP Envy 6000 series printer to the EE Smart Hup Pro. I have created a compatible network but it still doesnt work. Very annoying.
So techmates, what wireless printer would y'all recommend, under £100 that you know will work with EE Hardware. I have only been on EE Fibre for 7 days!!!
Spyboy
I am also having real problems connecting HPEnvy 6000. I have set up a compatible network, successfully, but... using the HPSmart  to effect connection it says the printer is not turned on, it is! How do I designate the Compatible Network for the printer to connect to? This should be really simple and was with BT Router. FFibre is very good though.
