close
Fibre 100, or is it ?
Gordon57
Skilled Contributor
Skilled Contributor
We changed the service to Fibre Max 100, still with EE. The line seems to be running around 107Mbps but the Think Broadband site suggests we should get 145-160Mbps on this service. Who is right here?
(ref: https://www.thinkbroadband.com/isps/everythingeverywhere/packages/fibre-max-1-broadband )
The installation was by Openreach, did they set us up right?
++ Fibre Max 100 Broadband without landline ++
36 REPLIES 36
I never said it was G.Fast. I was saying it was simulating the G.Fast characteristics.
Gordon57
Skilled Contributor
Skilled Contributor
@psychopomp2 How do I connect to the ONT? I've used the EE router so far, with nothing but the main PC connected for some trials. Didn't seem to make any difference.
I always get the same 106-108 on Speedtests, I checked that with ThinkBroadband.
It was my assumption that there was a cap applied, perhaps set wrong, hence the start of this discussion.
@XRaySpeX I didn't say you were on about G.Fast, it was saying that much had been discounted.
Connect a PC to the ONT by Ethernet.
On a Windows PC: Network & Internet Settings > Dial-up (don't worry!) > Set up a new connection > Connect to the Internet > Broadband (PPPoE). Then supply your EE BB Username & pwd & Connect. You should be then be up & running.
Now take a speedtest. There's a good chance it will be significantly faster as other BB Forum threads which have reported slow speeds on FTTP thro' the EE Smart Router, e.g. Broadband speeds FTTP  .
OP,
what do you get when you test with Ookla (speedtest.net)? I say this because the thinkbroadband.com speedtester never gives me more than 200-300 Mbps (multi-thread) on my 1 Gig TalkTalk line yet I consistently get 800+ Mbps on Ookla tester (any server).
Gordon57
Skilled Contributor
Skilled Contributor
@psychopomp2 Speedtest.net shows the same 107Mbps, on  the online version and the M$ download version as well. I tried, several times...
I'm a bit stuck with logging on to the ONT as I don't have a password, and the router says I don't need one?
If your BB Username looks like PRODUCTIONHQNUN123456@fs, your password will look like HQNPASS123456. Simply replace the numbers in the password, with the ones found in your username.
Gordon57
Skilled Contributor
Skilled Contributor
I've tried all of that, checked that I entered everything corrctly, chaged the username and password to suit, and got 'error 651' whatever that is. Google suggests I need special software to fix it, dunno why.
