on 28-12-2021 08:24 AM
I have had my fibre broadband contract for approximately 8 years. I still have the original router that came with the contract. For the past few weeks our internet connection has been dropping out and we have to turn the router off to reconnect it. I have tested the internet speed and it appears to be working ok. Could it be the router? How long do the last? Thank you. Jackie
on 28-12-2021 08:36 AM
@jackiehn Are you in contract or out of contract because no contract lasts 8 years. Have you upgraded within this time frame ? If you haven’t upgraded you’ll probably get a better deal if you do so you’ll pay less as you’ll be in contract. It’s cheaper when in contract.
The router should last the only time it could fail would be if it had a hardware issue and then it wouldn’t work at all.
on 28-12-2021 11:52 PM
Which router do you have?
@Chris_B : These contracts last indefinitely for as long as you & EE let it. As do routers.
on 03-01-2022 11:26 PM
This sounds similar to the problems I had with my ancient Brightbox 2. I found doing a full reset helped.
I 'replaced' my Brightbox 2 by simply calling EE Customer Services and they sent out a replacement. Unfortunately, I've found the replacement Smart Hub to be less functional than the Brightbox 2, so splashed out on a Draytek router...
04-01-2022 12:06 AM - edited 04-01-2022 12:07 AM
My old Brightbox 2 has never exhibited a significant fault other than the rare reboot (never reset) needed when it gets its knickers in a twist (as do most other routers). I am still using it on VDSL as, as you noticed, it is functionally far richer than the EE SH. I maintain a Guest Network (multiple SSIDs/VLANs) & Bandwidth Control.
