close
Fibre 100, or is it ?
Gordon57
Skilled Contributor
Skilled Contributor
We changed the service to Fibre Max 100, still with EE. The line seems to be running around 107Mbps but the Think Broadband site suggests we should get 145-160Mbps on this service. Who is right here?
(ref: https://www.thinkbroadband.com/isps/everythingeverywhere/packages/fibre-max-1-broadband )
The installation was by Openreach, did they set us up right?
++ Fibre Max 100 Broadband without landline ++
36 REPLIES 36
Gordon57
Skilled Contributor
Skilled Contributor
How do I check if I no longer have a phone line ?
Mustrum
Depends on how far away you are to the cabinet.
What does the BTW DSL check say for your line?
Sight of your router stats would confirm .
Mustrum
Plug a phone in see if you can dial a number - 17070 would be a good start.
@Gordon57 : What are you wanting to check?
@Mustrum : No point in plugging in a phone when you have no landline.
@Gordon57   That’s average it doesn’t say you will get.
Aphid
Try ringing your phone line number, to see if there is a connection, or
contact your provider and ask.
Gordon57
Skilled Contributor
Skilled Contributor
@XRaySpeX  See what the BT checker says I can get I think.
You're right with the phone line, I don't have  one to plug a phone in to...
Gordon57
Skilled Contributor
Skilled Contributor
Strange, as the EE site says an average of 145Mbps.
https://ee.co.uk/help/help-new/broadband-and-landline/home-broadband/how-can-i-improve-my-broadband-...
See the Fibre Max 100 entry at the bottom of that page. The engineer says I could get 500Mbps on this line.
@Gordon57 : Call CS & ask for your Access Line ID (ALID) & use that for the BTw Availability Checker.
