21-08-2021 09:29 PM
I am trying to upgrade my phone contract using a discount code that was generated directly from the EE Perks Website. I enter the code at the checkout and it comes back as an invalid code. Please can someone explain why this is.
22-08-2021 09:17 AM
I hope you're well and having a nice weekend, other than this issue of course.
Could I just check how long ago the code was generated?
22-08-2021 03:45 PM
The code was generated yesterday
23-08-2021 07:55 AM
Which plan or package are you looking for, @brendonsmith39?
Couple of points to note:
30-08-2021 10:14 PM
@Christopher_G I'm on a sim only plan upgrading to a phone plan and not using a VPN and not selecting anything on any other discounted offer. These codes are supposed to be able to be entered online only and are not working and have not worked for years looking at when the date of the first time this problem was reported. Is it not about time that the system was sorted out.
31-08-2021 08:31 AM
Thanks for getting back to me, @brendonsmith39.
The Perk codes do work for the majority of customers and if they don't there's usually a reason why. It's difficult to try and find out why it isn't working for you though From what you've told me, you're doing everything right.
I'd recommend speaking to our Mobile Care team so that they can try and add it for you, or investigate why it isn't working.
