09-02-2024 07:00 AM
After changing from bt to EE at their (bt)suggestion. Couple days fine now Netflix and amazon won't load, download on 4g 28mbps , yet worked on bt at 2.5 mbps. Any help please , suppose to be plug and play not having to re program routers, tv etc.
09-02-2024 08:13 AM
Morning @David455
Which device/router are you using?
Are you connecting to a TV to watch these apps?
Can you watch other apps?
Leanne 🙂
09-02-2024 08:28 AM
09-02-2024 08:30 AM
Thanks @David455
Have you tried restarting the router and TV and connecting the TV again to see if this works for you?
Do you have any other devices connected?
09-02-2024 08:45 AM
09-02-2024 08:51 AM
Thanks for the quick reply @David455
Could you check your postcode to see if we have any signal problems reported on the EE Coverage & Network Status Checker | Check your signal, please select 'check status' is anything showing?
09-02-2024 10:02 AM
09-02-2024 10:05 AM
Thanks @David455
In this case, please call us and our tech guides will get this fully looked into for you.
Let me know how you get on 🙂
09-02-2024 10:42 AM
09-02-2024 10:47 AM
