19-02-2026 10:15 PM
Hello a strange one indeed,
I'm on EE's 900 core full fibre, using the Smart Hub 7 Plus SH35A with the latest firmware (confirmed by a quick Google search).
The speeds and pings are fine (confirmed on other devices and on my PS5 Pro via the connection test and in-game ping meters) yet downloading is impossible due to the fact it's stating it'll take hours to finish downloading. Earlier this week my PS5 Pro was working fine, my Series X and Switch 2 currently work even with this weird issue happening right now.
I use ethernet on all of my consoles and I even swapped the ethernet cable between my Series X and PS5 to rule out a router and/or ethernet cable problem yet the problem remains. Switching to wireless resulted in the exact same problem on my PS5 Pro - there was no difference. I even did a factory reset of my PS5 Pro which allowed me to download one game at normal speed before it slowed to an absolute crawl afterwards when the next queued item (only a 15gb DLC) resulted in the same lengthy time period.
I can only assume and make an uneducated guess that it's an issue between EE and PlayStation specifically - as my Series X and Switch 2 are downloading games perfectly fine without any problems at all.
Very curious, can anyone else replicate this with their own PS5 (Pro or regular)?
Thanks in advance.
11-06-2026 08:55 PM
11-06-2026 09:01 PM
@ReadyUpEm Make it simple buy and use your own hub, ISP hubs are just what they are. BT one will work just fine for your connection, wireless may not hit the 900Mb/s giddy heights but Ethernet no sweat on the BT Hub.....
11-06-2026 09:18 PM
11-06-2026 09:25 PM - edited 11-06-2026 09:26 PM
@ReadyUpEm Box it up, stick a note in the box to the why, your acc number and send them all back, take a photo box open and do the returns linked below, do NOT allow it to get to the stage of fighting your corner, you will not win that battle.....
Return and recycle your EE Broadband or EE TV products | Orders And Returns Help | EE
11-06-2026 09:41 PM
14-06-2026 12:30 PM
Hey there,
Sorry for the late response, i have figured out the fix for this. All you have to do is turn the ipv6 mode from stateless to off, after doing this your hub will take a few minutes to reconnect and then it will fix your download issues.
14-06-2026 01:01 PM
@Skirrt Did you report that finding to EE so that it could be looked into?
17-06-2026 04:03 PM
I just wanted to thank you for providing the solution IPv6 allocation mode off it sorted my ps5 download speeds I had been tearing my hair out over this issue
once again many thanks
02-07-2026 06:27 PM
You legend! This worked for me thanks.
