on 27-08-2023 05:51 PM
on 27-08-2023 06:02 PM
Have you tried manually connecting to router by WiFi? You will need to supply to the TV the router's SSID & WiFi pwd.
on 27-08-2023 06:14 PM
Hi I’ve tried doing that with both WPA2s as the security type but they both didn’t work
on 27-08-2023 06:17 PM
Show me the screen of it not working.
on 27-08-2023 06:34 PM
They was 2 WPA2 types and both of them couldn’t connect to the network, I don’t know if it’s a tv problem or wifi problem
on 27-08-2023 06:38 PM
Nor do I until I see what it is saying.
on 27-08-2023 07:00 PM
Not at home atm, will look when back
on 07-02-2024 10:27 PM
Same problem, bought this today as old tv (LG)suddenly stopped working. This brand new tv connected for long enough to set up but now has no connection and can’t find the network
on 17-09-2024 11:02 PM
Same issue. It’s the EE router for sure blocking it. Any fix for this?
on 18-09-2024 01:56 PM
Hi @MarkyPh,
Welcome to the EE Community 🙂
Is the Wi-Fi network not being found at all on the TV, either via the WPS or Add network option?
But you are able to connect other devices to your EE Wi-Fi fine? Can the TV connect ok to other Wi-Fi spots, such as a hotspot on your phone?
If it is just the one device having issues, there are some things you can check. You will first need to access your router admin page, type 192.168.1.254 in the browser address bar. Login using the admin details on your router or the keep me card.
From there within settings look for the 2.4Ghz and 5Ghz band, some devices will have a better chance connecting on 2.4Ghz so try disabling the 5Ghz and see if the TV then is able to find and connect to the router. Worth trying the other way around as well if 2.4Ghz does not change the result.
I would recommend following all the steps on this guide from Samsung for further help
How to troubleshoot internet connectivity for Samsung TV | Samsung UK
Alex
