Ee broadband FTTP using Bt hub 2
Bluesriff7
I have got a Bt smart hub 2 and I can’t sign
into it. Using Mac book keeps saying unsafe
connection, use https which I have tried but
it does not work. Bt instructions how to bypass
the warning. Safari select show details/ select
visit website/,confirm by selecting vist website.
cant find how to do that? And just tried
my ee app on my iPhone broadband hub
settings that says unable to connect at the
Moment
You are logging to your BT Smart Hub 2 at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router? Using it on EE BB shouldn't make any diff.
Maestro
Maestro
Bluesriff7
I have tried that, justs says use https
@Bluesriff7  Not the last time i logged onto one in April. It was still http://192.168.1.254 at that time.
You've done this dance before.
Bluesriff7
I use safari then go into settings and it gives the
option to set the browser to use
i use duck duck go.
