04-11-2024 11:35 AM
I am a new EE customer, BB works but the Smart Hybrid Connect is paired to the route but the three bars are flashing red. I have moved around the house and it is in the best possible position for 4g.
04-11-2024 01:47 PM - edited 04-11-2024 01:48 PM
Good morning @Thumper75.
Thanks for reaching out to us via the EE Community 😊
Just to be sure first of all, when you first received your Smart Hybrid connect did you set this up with your Hub as advised on our help page here?
Peter
09-11-2024 10:21 AM
I have the same problem on my brand new EE Hybrid Connect set.. followed instructions, have tried factory reset too, blue light is steady but 4G bars still flashing red
09-11-2024 11:28 AM
If you're confident that there is an EE mobile signal in your area then it sounds to me like the SIM card in the modem is not provisioned correctly. If so, you'd need to get in touch with the helpdesk.
21-03-2025 10:02 AM
Did you get a resolution as ive got the same problem?
21-03-2025 10:03 AM
Ive got the same probelm was there a resolution?
21-03-2025 10:03 AM
I have the same problem and received a new hybrid connect but issues are the same.
21-03-2025 12:54 PM
Hi @Fred-1962
Do you have a good mobile signal in your property? Best way to test is with another EE device.
If you don't have one, you can check the expected coverage on our coverage checker.
02-04-2025 03:23 PM
I’m having the same issue. I “upgraded” from BT to EE, but they didn’t send a Hybrid Connect. I called them, and they sent one, but it wasn’t provisioned. After several conversations, they said it needed to be provisioned, then later decided to send a new one instead. That order got stuck in the system for a week. They eventually removed the order, so I had to call back, and now they’re supposedly sending another one—but it’s delayed again.
I’ve wasted hours on the phone, struggled to get anyone to take ownership, and been promised multiple callbacks even given someone’s ee email who then ghosted me (hello Barrie) —yet only one person actually called me back yesterday. At this point, I’m certain it’s just going to get stuck again.
has anyone resolved this issue.
yes I have EE signal and a connection to the router.
05-07-2025 04:21 PM
I had the same symptom. EE advised trying factory reset of the HC — worked for me, but I had to pair the HC to my hub again.
