26-10-2026 08:49 AM
Yesterday we had the first power cut of the season which only lasted 10 minutes. After the power came back on my EE Smart Hub 6Plus sat continuously on green with the odd flash. My BT hybrid connect could not connect to the router. I have a hybrid connect, Hive Box and phone also connected to the router. I tried unplugging all these, restarting and resetting to no avail. Went up to the attic and dug out my trusty BT Smart Hub router which I had kept and plugged everything in and was up and running in minutes. Clearly something had happened to the EE router with the power cut. Being sent a new router. Just wondering if this is a common issue with EE routers? Only had it a few months. Had my BT one for years and never had an issue. Just worried we are away on holiday and cannot access our Hive heating system if it happens frequently.
26-10-2026 09:25 AM - edited 26-10-2026 09:38 AM
@RSK0911 It was a common fault that the 6+ psu adapter did not survive a brownout with power failure so it never survived or recovered, the Hubs were fine, you may wish to try just the new adapter when you get the replacement first.
Just one off the search links below for you. plenty more have a look, would do so but running on mobile data just now due to downed snapped fibre cable after the storm other day.
Solved: Ee 6 plus router green and orange cycles constantly - The EE Community
26-10-2026 11:12 AM
26-10-2026 12:06 PM
@RSK0911 There was a few varying display symptoms when the PSU packed in, and Green occasional flash orange or white etc sometimes a 10minute connect then off again, but sure is worth the PSU change first, there was never a reported Hub failed just the PSU went bad.☹️
26-10-2026 12:20 PM
26-10-2026 12:28 PM
if thr router is bad or dead contact customer service
29-10-2026 01:53 PM
Hi Jim - thanks so much for your suggestion. It was the PSU as old hub worked fine with the new plug. Saved a lot of work changing passwords everywhere! Will also buy a surge protector extension cable to see if that helps for the next power cut. Only took 4 days for the new router to arrive with Evri haha / why not use PO tracked 24 or 48. Evri delivery so slow in rural Scotland!
29-10-2026 01:54 PM
First thing I did
29-10-2026 02:25 PM - edited 29-10-2026 02:50 PM
@RSK0911 As it was/is a known fault with the PSU, hopefully the replacement was one that the Manufacturer has sorted out with your replacement Box, replacement's are normally used units so just keep it all in the forefront of your mind they just never seem to survive rapid powercut's or brownout's very well, any issues you may be better to see if EE would supply you a BBU to replace as the output on that is a direct battery connection.👍 The amazon one below but you need to use the correct matching tip for the 6+ hub. 3.5 x 1.35mm one. You should also be able to use the PSU from the BT SH2 as that tip will also fit that adapter as well.
