15-11-2026 01:24 PM
Ok, a bit of a mish mash here! I an EE broadband full fibre subscriber but have a BT SmartHub2 router from when I was with BT.
I guess EE saw what I had so didn't bother sending their own branded SmartHub. Anyway, it all carried on working from the BT/EE switchover without any input from me so I've had little reason to complain about this.
But - my next broadband provider could possibly be back to BT (so not a problem) or the Plusnet brand of the BT group, which is where I would appreciate advice.
Apparantly, using a BT SH2 for Plusnet is fairly widespread so I don't think I would be planning anything too challenging. All you need to do is change the username and password in the router hub manager, then plug in the ethernet cable. So, I thought I would try a "dry run". I managed to access the Hub Manager and found a Broadband Username and Password line which I imagine would be the bits I would need to change.
This is where I got stuck. There was no obvious way to actually change and then save new settings here. Nobody has flagged this as an issue on the Plusnet forums, so I am possibly doing something incorrect here. I have read the entire Baldrick thread on this topic to no avail - could somebody on here advise?
Needless to say, I could just plug and play if I used a supplied Plusnet router, but I'd rather not do that due to basic nature of the router.
Many thanks for reading this far!
15-11-2026 01:35 PM
@snes wrote:Apparantly, using a BT SH2 for Plusnet is fairly widespread
But you do have a BT SH2. So it should work for you also w/out having to change any creds. Presumably PN BB accepts the BT creds.
15-11-2026 01:38 PM
@snes PN creds are NOT the BT ones, the BT Smart Hub 2 is not going to work on a PN Connection.
15-11-2026 04:34 PM
Jim, could you elaborate? Do you mean that the BT Smart Hub 2 won't work at all with Plusnet even if passwords etc are changed?
15-11-2026 04:43 PM
As you discovered the creds in the BT SH2 are unalterable. So if PN BB won't accept them as is, it won't work on PN.
15-11-2026 05:28 PM - edited 15-11-2026 05:40 PM
@snes If you wish to use a NON PN supplied Hub, you need to get one that allows the changes for the Wan section, that is not ANY off the latest BT or EE as well versions. If you do move back to BT from EE, also depending on what you go for package wise then they may change you over to the BT Smart Hub 3 version which is just the EE Smart Hub6+ in BT clothing also depends at the time and what you are doing.
16-11-2026 04:15 PM
Many thanks to Jim and XRay for your helpful responses! I have now been told that the common use of BT hubs for PN refers only to the earlier hubs (hub1?) which may explain my initial puzzlement.
Were all SH2s locked down?
My main need to keep my SH2 was because it works with my black BT disc. Do the earlier hubs work with this disc? And does the SH3 link up with the black disc?
Sorry to keep asking questions, and thanks again for previous help - your knowledge is appreciated!
16-11-2026 05:32 PM - edited 16-11-2026 05:37 PM
@swtrains No the Black Complete wifi disc's only work with the BT Smart Hub 2 and the EE SH20A versions.
The BT SH2 has been locked down from day DOT that is how long 6 years about time wise. Go back to BT the hub works on that. The SH3 is a EE Smart Hub 6+ in BT clothing and again the complete WiFi Disc's DO NOT WORK with that hub, BT has there own new version to match shape colour etc or use the EE version SW30A available on flea bay for it all. The EE all below if you need, click device to break it all out to everything.
17-11-2026 10:59 AM
Jim, your comprehensive reply was much appreciated, and convinced me that the best course of action would be to stick to BT or invest in a third party mesh system.
However, I have since discovered the following. When the WAN cable is connected to the SH2, the broadband username and password are "greyed out" on the router ie, no option to change is offered.
But when the WAN cable is removed, the broadband username and password sections both then show the details in a box with a drop down box offering the chance to change both. So, yes, possibly the SH2 could have the PN credentials entered and saved and therefore used with Plusnet?
Presumably, entering a Plusnet username and password, then reconnecting the WAN cable to a Plusnet line would then allow me to use my SH2 for my Plusnet service?
Your greater knowledge may well be able to shoot down this option or confirm it as a possibility - I look forward to your comments!
17-11-2026 11:19 AM - edited 17-11-2026 11:33 AM
@snes Change them to what ever and save, reboot the Hub and see if the stick as is in the fields. If you need the BT ones they are in the Help search third part hub.
Edit:- As a little footnote, i have had my Asus on three connections now, EE using the BT creds, Sky which uses no creds but is setup as DHCP, and now on VF using there creds. As long as you can change them in that BT Smart Hub 2 then there is the possibility that it will work, if you know off a PN user they may let you test it out on a PN connection.
