Samsung smart TV won’t connect to my ee wifi
Haighy1
  • image.jpgMy Samsung smart tv won’t connect to my ee wifi smart router, the wifi works fine on the phone, when I try to connect it to the wifi the tv can’t find a network, I have tried to do it manually and that won’t work,I have also reset the tv network settings and also there is no WPS button on the router so I can’t connect to it with that either, can anyone help?
20 REPLIES 20
I have tried all the steps. The TV can connect to my hotspot no problem. Turned off 5GHz so only 2.4 still no luck. TV is the Samsung Frame located 3m away from the router.
Was working fine with my previous provider.  I don’t know what the issue is here but it’s frustrating the hell out of me.
Samsung have been through troubleshooting and said the problem is with your SP.
Not a great start to my journey with EE. Had no end of problems.
im hoping someone can give me the answer I need.
Hi I originally posted about my tv not connecting, it eventually worked after restarting/ resetting the tv, try this to see if it works
Alex_H
Thanks for sharing that you got it working and what resolved it for you @Haighy1
@MarkyPh I am sorry you have been having issues since joining, I appreciate it can be frustrating when things are not working easily. Have you been able to test with a wired connection between router and TV?
If you have the security set to WPA3 which you should be able to see in the admin page, your TV may not be compatible with this. You should be able to change this to WPA2 or other options to see if the TV is then able to connect.
Alex
Wire, why? Who uses wires. It doesn’t solve my issue.
Peter_W
@MarkyPh The reason we will often ask customers to test a wired connection is so we can identify if the issue lies specifically with the wireless connection, or elsewhere.
If you're not able to try this, then I'd definitely recommend trying some of the steps @Haighy1 and @Alex_H have recommended too.
Peter
The tv can see the SSID and can connect to my personal hotspot. That’s enough for me for a test.
This whole experience with EE is shocking. 30 cooling off period … I’ll take it.
No, @MarkyPh , 14 day.
great my services only went live yesterday. Worst customer service I’ve ever experienced in my life
Hi
I have had a nightmare with EE after changing from Sky to get 5ghz. My samsung tv can only connect on the 2.4ghz on a ee comp connection. EE should alert customers that there is a problem with old samsung tvs not connecting. I bought the router in good faith not aware at all that there is a problem.
@Best73 That is why EE introduced the Compatible Network feature exactly for those situations like you have not a sky feature but work arounds also on there help site for the old/new types of sky Hubs.
And it is just not TV's can be any device and also brand new recent may also have issues, until they are tried who knows at least you got it all working. 👍
