Smart Hub 7 Pro 5 GHz failure reproduced on two hubs - channel/firmware issue?
Mellman
Hi all,
I am starting a separate thread for this because although the problem originally came to light while troubleshooting repeated YVM102/connectivity problems with our EE TV boxes, the testing we have done since then appears to have uncovered a wider Smart Hub 7 Pro 5 GHz issue.
We are on EE Full Fibre using an Openreach ONT and a Smart Hub 7 Pro. We also have an EE TV main box downstairs, an EE TV Mini upstairs and an EE WiFi extender.
The original symptoms were intermittent connectivity problems with the TV boxes and other devices. Eventually I noticed that our gaming laptop could still see the normal EE WiFi network but would sometimes be unable to connect to it over 5 GHz. If I changed the wireless adapter back to dual band it would immediately connect using 2.4 GHz.
After extensive troubleshooting with EE, including a factory reset of the original Smart Hub, Executive Complaints arranged for a replacement Smart Hub 7 Pro to be sent.
I deliberately installed the replacement in a very controlled way. The EE extender was left completely powered off and initially nothing else was connected to the replacement apart from the Openreach ONT. I connected my desktop directly to the new hub over WiFi.
The desktop uses an Intel WiFi 6E AX210 adapter. On initial setup it connected normally to 5 GHz with a strong signal and no packet loss. At one stage the replacement hub was using channel 36 and everything was working as expected. The gaming laptop, which uses a separate Intel AX200 adapter, also worked normally.
The replacement hub then remained apparently fine for around four days.
Unfortunately the same problem returned.
The gaming laptop lost its 5 GHz connection again. When its adapter was restricted to 5 GHz only, it could see the EE SSID but Windows reported "Unable to connect to this network". Returning the adapter to dual band allowed it to connect immediately over 2.4 GHz.
I then repeated the same test independently on the desktop. When I restricted the AX210 to 5 GHz only, it also could not connect.
At this point the EE WiFi extender was still completely powered off, so the extender or mesh roaming can be excluded from these tests.
Hub Manager showed the main 5 GHz radio as enabled and Smart Channel had selected channel 100.
I ran:
netsh wlan show networks mode=bssid
on the desktop. Initially the only BSSID being shown for our EE network was the 2.4 GHz BSSID. The Smart Hub's 5 GHz BSSID had disappeared completely from the scan even though Hub Manager continued to report 5 GHz as enabled on channel 100.
I then used the 5 GHz Smart Channel Rescan option in Hub Manager. It remained on channel 100 and did not resolve the problem.
Next I switched only the Smart Hub's 5 GHz radio off, saved the setting, waited around 30 seconds, switched it back on and saved again.
After doing that, the 5 GHz BSSID became visible again on channel 100 with a strong signal of around 80 percent.
However, neither the desktop nor the gaming laptop could actually connect to it.
This was particularly useful because it showed that simply making the 5 GHz radio broadcast again did not restore the ability of clients to associate/authenticate successfully.
I generated a Windows WLAN report on the desktop while the fault was live.
One failed connection attempt is particularly interesting. Windows recorded that wireless association with the Smart Hub's 5 GHz BSSID succeeded. WPA3-Personal security then started, but approximately five seconds later the security stage failed.
The reported reason was:
"Dynamic key exchange did not succeed within configured time"
Windows also logged:
"PSK mismatch suspected"
The WiFi password was definitely correct. The same SSID/profile/password continued to work on 2.4 GHz and had previously worked normally on 5 GHz on the same replacement hub.
The WLAN report also confirms that the Intel AX210 supports WPA3, SAE and H2E, so this is not simply an adapter which lacks WPA3 support.
As a further test, I enabled the Smart Hub's Compatible WiFi network on 5 GHz. This uses WPA2-Personal rather than WPA3.
Hub Manager showed Compatible WiFi 5 GHz as enabled on channel 100.
However, when I restricted the AX210 to 5 GHz only, the Compatible WiFi SSID disappeared from the available network list completely. The normal EE 5 GHz SSID remained visible but could not be joined.
That makes me less convinced that this is simply a WPA3 problem. It seems possible that the failed WPA3 key exchange is one symptom of a wider 5 GHz radio, virtual AP, Smart Channel or firmware state problem.
At this stage I performed a normal restart of the Smart Hub through Hub Manager. This was not a factory reset.
After the restart, Smart Channel selected channel 149 rather than channel 100.
The result was immediate.
The desktop automatically connected successfully to 5 GHz again on channel 149 using WPA3-Personal.
The gaming laptop also immediately regained proper 5 GHz connectivity. Windows shows it connected on channel 149 using WiFi 6/WPA3, with a current link speed of around 721 Mbps receive and 360 Mbps transmit.
The upstairs EE TV Mini box, which had also started having connectivity/interface problems again at approximately the same time as the 5 GHz problem returned, also began working normally again after the Smart Hub restart.
I am not claiming that this proves channel 100 itself is the cause because the restart changed two things at once. It reset the hub's internal state and also caused Smart Channel to move from channel 100 to channel 149.
However, the observed sequence on the replacement hub so far is:
5 GHz working normally while the hub was using channel 36.
5 GHz subsequently failing while Smart Channel was using channel 100.
Two completely independent computers unable to use 5 GHz.
EE extender completely excluded from the setup.
Smart Channel Rescan did not resolve the problem.
Cycling only the 5 GHz radio caused the BSSID to become visible again but did not restore client connectivity.
Windows WLAN diagnostics recorded a WPA3 dynamic key exchange timeout against the Smart Hub's 5 GHz BSSID.
The WPA2 Compatible WiFi test also failed to provide a usable 5 GHz alternative.
A full Smart Hub restart then moved 5 GHz to channel 149 and restored normal 5 GHz operation on both computers.
The EE TV Mini also returned to normal operation following the same restart.
What makes this especially concerning is that this is now the second Smart Hub 7 Pro on which we have experienced very similar 5 GHz association failures.
The replacement hub is running firmware:
r4.29.1-R-1930437-PROD-1
The previous Smart Hub was also running this firmware when we reproduced the earlier 5 GHz failure.
The desktop and gaming laptop use different adapters, Intel AX210 and AX200 respectively, and both are now behaving normally again following the hub restart. That makes a fault with one particular client considerably less likely.
The lack of manual 5 GHz channel selection on the Smart Hub also makes this very difficult to isolate further. Ideally I would like to be able to lock the hub to a known working non-DFS channel such as 36, 40, 44 or 48 for several days and see whether the fault ever returns, but as far as I can tell the Smart Hub 7 Pro does not allow this.
For now I am leaving the hub exactly as it is on channel 149 and monitoring it.
If the fault returns, I intend to capture the selected channel, BSSIDs, client behaviour and WLAN diagnostics again before restarting or changing anything.
I would be very interested to hear from anyone who has seen similar behaviour with the Smart Hub 7 Pro, particularly a situation where 5 GHz remains visible but clients suddenly cannot associate/authenticate until the hub is restarted.
I would also be grateful if someone from EE could advise whether these findings can be passed to the team responsible for Smart Hub 7 Pro wireless/firmware development. Having now reproduced similar behaviour on two separate hubs, with multiple independent clients and the extender excluded, I do not think another factory reset or replacement hub alone adequately explains what is happening.
43 REPLIES 43
Maestro
Maestro
@Mellman Going to take a bit off reading but the below 5Ghz was alleged to be fixed that FW version....
Firmware version: r4.29.1
Deployment date: From June 2026
Hub Type: SH40J
Release notes:
  • Fix - Connectivity Backup not working over WiFi
  • Fix - 5GHz WiFi sometimes stops working after firmware update
Do you happen to have a wifi analyzer on a mobile device to confirm what is being seen actually signal wise, cannot tell that from your long post?
Maestro
Maestro
@Mellman
If you can also include your captures will allow looking at with a bit more depth, although i do band separate the Triband Hub and can fix the channel were ever i want/need it to be also have zero neighbouring issues. Also running 160Mhz double width channel that netsh cannot display. So Channel 100 (114).
C:\Windows\System32>netsh wlan show networks mode=bssid
Interface name : WiFi
There are 1 networks currently visible.
SSID 1 : SKY6xxxxxx
Network type : Infrastructure
Authentication : WPA2-Personal
Encryption : CCMP
BSSID 1 : a0:xx:xx:xx:xx:xx
Signal : 97%
Radio type : 802.11ax
Band : 5 GHz
Channel : 100
Bss Load:
Connected Stations: 2
Channel Utilization: 66 (25 %)
Medium Available Capacity: 0 (0 us/s)
QoS MSCS Supported : 0
QoS Map Supported : 0
Basic rates (Mbps) : 6 12 24
Other rates (Mbps) : 9 18 36 48 54
Mellman
Thanks Jim, that's really useful, particularly the r4.29.1 release note. I hadn't realised that version specifically contained a fix for 5GHz sometimes stopping working, so the fact I've now reproduced a very similar failure while actually running r4.29.1 is interesting.
I'll get a WiFi analyser onto my Android phone and take some captures of the 5GHz environment. The hub is currently healthy again following the restart and has selected channel 149, so I'll capture that as a working baseline first. If the fault returns I'll capture exactly the same views while it is broken and before restarting or changing anything.
The 160MHz point is also interesting. I hadn't appreciated that netsh showing channel 100 wasn't giving the whole picture in terms of the width being occupied.
Is there anything particular you would like included in the captures beyond the 5GHz channel graph, BSSID, signal level and channel width?
@Mellman No you have got it well under control by the looks of it, Netspot by ETWOK Inc, free version do not buy it is good on Android, Windows PC version is a bit fluffy but a little useful at times. Got some old captures so will find link etc, just ignore my sky name, kept it for years, no need to reinvent the wheel. Netspot WiFi Inspector part off it below.
Re: Wifi issues - Page 3 - The EE Community
No Longer an EE User, never had a 7 Pro 6+ was mine for the 11 months i managed to hang in there for, 100% Asus AI mesh wired / wireless backhauls with some Tp Powerline in the mix awkward spots.... Fresh pics if you need them let me know.👍
Mellman
Thanks Jim. I've now got WiFi Analyzer running and this is the current healthy state.
The hub has moved itself back to channel 100 since the restart and is currently working normally. The analyzer shows the main 5GHz BSSID on channel 100, centre channel 114, using 160MHz width, with my phone connected successfully at around -63dBm.
I've also confirmed that both the Intel AX210 desktop and Intel AX200 gaming laptop are currently connected successfully on channel 100 as well.
So channel 100 itself clearly isn't inherently unusable by the clients. If the fault returns while the hub is still on channel 100, I'll capture this same graph before changing or restarting anything so we have a direct healthy versus failed comparison.
There also doesn't appear to be any significant neighbouring 5GHz WiFi overlapping the 100/114 block in the current capture.
@Mellman Will take a look when your posted picture gets cleared for general viewing.👍 Will also take a look at you Intel's when i get a little time tomorrow, think i also have both those versions also desktop/laptop although will say never ever had an issue whatsoever with them at all. Link below to how the channels look mesh node.
Re: 'Compatible Wifi' issues with new Smart Hub Pro and Smart Wifi Pro - The EE Community
Updated pictures when cleared for viewing. Low value Tp is the next door neighbour's normally he has it on 40Mhz wide channel and it is on Netspot Channel 5 to 11, what can one say? To low to bother anything for me....
2.4Ghz setup. Channel 1 is in use just too far to show up the connection.2.4Ghz setup. Channel 1 is in use just too far to show up the connection.5Ghz setup, CH36  80Mhz CH100 160Mhz width's.5Ghz setup, CH36 80Mhz CH100 160Mhz width's.
@Mellman Picture cleared and looks good, strength matching in your wifi6 bars about correct as well with one bar dropped.
@Mellman Slight oops, Desktop has a MediaTek Wi-Fi 6E MT7922 160Mhz Wlan,
Laptop is an Intel Wi-Fi 6E AX211 160Mhz Wlan, any how fired them both on now running combined Lan/Wireless operation and will leave that way for a week or so, again been on many times zero issue.
Will check the wifes laptop when she heads off to bed for the night, it's a daily user but connects on the Node at 80Mhz wide Ch36 all the time where she use's it, will let you know but expect it's up there type wise as an Asus workhorse for her. If there was one single issue with it she would be screaming as she does not must be working perfect....
Mellman
Hi Jim, thanks again.
The fault has actually reproduced again this morning on the replacement Smart Hub, and I have managed to capture considerably more information while it was live.
The EE TV Mini started having the same guide/interface connectivity problem again. At the same time my desktop, gaming laptop and phone had all ended up on 2.4GHz, despite the Hub Manager still showing 5GHz enabled on Smart Channel 100.
Using WiFi Analyzer on the phone, the main 5GHz BSSID 28:04:7a:ff:5a:03 was still broadcasting on channel 100(114), 160MHz, at a strong signal. Windows on the desktop could also see the same 5GHz BSSID at around 70 to 82 percent signal.
I then restricted the desktop Intel AX210 to 5GHz only and attempted to connect. It could see EE-5SH8QG on channel 100 but could not establish a usable connection.
I generated another Windows WLAN report during the failure. There were repeated association attempts which ended with:
"The driver disconnected while associating."
One manual attempt also ended with:
"The specific network is not available."
This was despite the same scan still showing the 5GHz BSSID strongly broadcasting on channel 100.
There was one complication during some earlier testing this morning because an old EE extender had accidentally been powered on by somebody else in the house and was broadcasting our previous SSID. I spotted this, unplugged it completely, confirmed the old SSID had disappeared, and then repeated the 5GHz-only AX210 test again.
The failures above are from that repeat test with the old extender completely absent.
Also worth mentioning that the Mini problem had already started before that old extender was powered on, so it cannot explain the initial recurrence.
For comparison, this exact replacement hub, same 5GHz BSSID and same channel 100(114) 160MHz configuration was working normally yesterday with the desktop, gaming laptop and phone all successfully using 5GHz.
I have the full Windows WLAN HTML diagnostic reports from both failure periods if any particular sections would be useful. I am reluctant to post the complete raw files publicly because they contain various PC and network identifiers, but I can extract any relevant event details.
