New EE's Full Fibre BB (FTTP) only running at max 950mb ? Should be 1.6 Gbps !
iJason
Valued Contributor
Valued Contributor
I had my new install today and its only running at max 950mb down and 115 up and it should be 1.6gbps
I have the new EE SMART Hub ! Can someone advise ?   I have Cat 8 Cable connected to the Yellow Ethernet ports.
Does it matter what port you put it in as its not got any label or marks to say otherwise. please advise as I am paying £25 more to get these faster speeds that I don't currently get.
70 REPLIES 70
iJason
Valued Contributor
Valued Contributor
Can you show me what PORT has the faster speeds on the smart hub as there is no way to tell ! As all the Yellow ports at blank !
Please advise. as only getting 950mb max and should be getting 1.6gbp
@iJason : All Ethernet ports on the EE Smart Hub Plus are 1 Gig. You'll only get anywhere near 1.6 Gig over WiFi.
garetc
Scholarly Contributor
None of the usable ports on the Smart Hub are over 1Gbps, you’ll not get over that speed using a wired connection (or wireless).
Many of us have bought our own WiFi 6E/7 routers with multi gig ports. If you’re not able to do that then you’ll need to wait for the EE WiFi 7 routers to launch whenever that might be.
When I spoke with the next gen team apparently the official line is that the 1.6Gbps connection is shared across wired and wireless connections and is not intended for a single device to get 1.6Gbps so the WiFi 6 router is fine on that basis.  🤷🏽‍♂️
cliffy37
Yep unfortunately EE sell a premium product with sub standard equipment. The hub is only capable of the speeds you are receiving.  They do have a WiFi 7 router in development but it uses there own firmware so will probably be restrictive and also substandard for a premium product.  I like many others have been out and purchased our own routers which range from£300 to £700 for a single unit, personally i got a Asus Rog Rapture BE98 which has been awesome with 4 x 2.5Gbe, 2 x 10Gbe and a 1Gbe Lan ports plus the WiFi 7 is maxing out my FTTP speeds with links direct to my server exceeding 3Gb. Problem is when you pat for a premium service you should not need to buy your own equipment (not without a subscription discount at least)
@cliffy37 There is always going to be the divide of a real router to a isp supplied both in speed and in quality of control/operation, know which one i would prefer to have!
cliffy37
@JimM11 - in this day and age there is no reason for either to be missing especially on a premium service.  I also have not double checked but i do not recall seeing it clearly mentioned on marketing materials that full speed cannot be achieved on a single device but i could be wrong on that
Maybe EE should take a more pragmatic approach and offer third party routers in the way they do Mobile handsets, i.e you can have our one for "free" or pay £xx a month for a different router that is actually capable. At least that way they are catering to the novice and the enthusiast which these high tier packages are clearly aimed at
For what its worth the current offering from EE for there router clearly cannot provide the speed OR Control / features
@cliffy37 An OP posted just the other day, he maxed out the EE router with his mobile and also his gaming laptop on wi-fi signal, there is so many combinations to get to wired speed, nic, hard disk, then also server speed, OR fibre cable speed and on and on. An isp router is designed to connect with minimum fuss and supply internet connection, try not to cause to many problems once its connected etc etc.  In an ideal world all those that have got the latest 1.6Gb/s package of either ilk, then EE when it ever gets done offer the latest router (in test no doubt) to those user's, doubt it will happen that way though. Who wants to be the tester!!!
iJason
Valued Contributor
Valued Contributor
Ok I just went and purchased TUF Gaming 3000 & just set it all up and its running but the speed is still the same ?
Its in Port 1 that should have speeds up to 2 Gb's    I have cat 8 cable running from my pc and cat 6 cable that connects from BT fibre port to the Router , Any one advise ?  Is there anywhere I can check what my Fibre speed is ?
garetc
EE are trialling their new WiFi 7 routers with a selection of customers and staff at the moment so the launch should be imminent. We don’t know the spec of the router, any anyone on it will not be able to discuss it with the forum.
I was one of the trialists for the SH2 on BT many moons ago. I missed out this time, didn’t meet the requirements for the trial but they’re not going to be able to beat my current router performance (Orbi RBE973S) so not that bothered.
