New EE's Full Fibre BB (FTTP) only running at max 950mb ? Should be 1.6 Gbps !
iJason
Valued Contributor
Valued Contributor
I had my new install today and its only running at max 950mb down and 115 up and it should be 1.6gbps
I have the new EE SMART Hub ! Can someone advise ?   I have Cat 8 Cable connected to the Yellow Ethernet ports.
Does it matter what port you put it in as its not got any label or marks to say otherwise. please advise as I am paying £25 more to get these faster speeds that I don't currently get.
70 REPLIES 70
cliffy37
@JimM11  The WiFi 7 router from EE has been in testing since at least Feb, i would of happily tested it as it is in the hand of public testers. Just last night i was downloading at 1.45gbs from the Xbox app on my PC while 2 over users in the house where streaming  4K. While i agree there is still a lot of legacy devices out there with WiFi 6/E and 1Gbe nics most new hardware is now being released with WiFi 7 and minimum 1 x 2.5Gbe. This is exactly why i said EE should offer up the option of adding a third p[arty router to your monthly plan should you so which to utilize the speed appropriately. I saw just last week ZEn (i think it s them) offering the Eero Pro Max 7 as an addition should you want it
cliffy37
@iJason  what is the speed of the LAN port on your actual PC / laptop if that's on 1Gbe you will be bottlenecked there. If that is not an issue i would reboot the ONT and router
garetc
Scholarly Contributor
The spec on that isn’t that far away from the SH3,  it’s still only WiFi 6.
Does it have multi gig Ethernet ports?
WiFi 6E and WiFi 7 are more able to deal with the 1.6Gbps connection but not many devices have the hardware for those standards. Even when you have a device that’s 6E or 7 the further away from the router the slower it gets.
cliffy37
@garetc  Are you talking about the Eero Pro Max 7? If so its WiFi 7 with 2 x 10Gbe ports and 2 X 2.5Gbe Lan ports. Unsure if the option is live yet or coming soon though. It was announced 2 weeks ago after checking along with teh announcement of there 2Gb package starting ion the Autumn
Brilliant Contributor
@iJason For all the star's to align, 1. your PC has to have at least a 2.5gb/s nic, 2. the router has to have the appropriate 2.5gb nic for the pc to plug into, 3. you have purchased the 1.6gb/s package from EE and up until midnight they can setup/change. 4. The fibre ONT has to have the model with it's 2.5gb/s lan/wan port for the Router Wan output - ONT Wan input. Model of the ont decides its speed, but the colour of the ONT rj45 NIC can also inform you of its speed.
Edit: the TUF 3000 is the same spec as the EE router, it only has a high speed wan output port, and only 4 - 1Gb/s lan connections.
iJason
Valued Contributor
Valued Contributor
I have https://www.msi.com/Motherboard/PRO-Z790-P-WIFI-DDR4/Specification
Supports 2.5G Lan so thats not the issue.
garetc
No - I was referring to @iJason post about the TUF Gaming 3000 🙂
@iJason Check the nic properties speed, you will find its at 1000/1000, because the EE and the TUF only both have GB/s nic inputs.
cliffy37
@iJason  Assuming you have the TUF V2 there is no single 2gb LAN port you have to use Link Aggregation with 2 cables to your PC to achieve the 2Gbe which need to be plugged into LAN ports 1 & 2 on your router
iJason
Valued Contributor
Valued Contributor
I have now returned that Router and purchased one that has dedicated 2.5gb Lan ports !  I'll let you know how I get on !  Still think its a massive Scam that EE are advertising the faster internet yet the hub they supply does not support these speeds! not even close.
