close
Using a Vigor 166 G.fast modem with EE Fibre max 300
Thomas1979
I have just bought a Vigor 166 G.Fast Modem to use with my WiFi 6 router and EE Fibre max 300 connection.
My broadband username is readytoconnect@fs
The guide says for the broadband password "you'll need the login details or the password that came with your EE router"
My question is does that mean the Wireless password/key or Admin password or something else? I do not have any other passwords other than my EE login to web account?
Any help gratefully received.
13 REPLIES 13
Alex_S
EE Employee
Hi @Thomas1979,
Welcome to the community 🙂
Have you tried to use the router WiFi password to connect?
Has this allowed access?
Alex 🙂
Modem arrives on Tuesday. Hoping to have everything ready for it hence the question. Thanks for your reply
Hi @Thomas1979,
Let me know how you get on when it arrives using those details.
Alex 🙂
Mustrum
Thanks yes I’ve read them but it’s not clear.
it says follow these instruction if your broadband user name is readytoconnect@fs and links to this
follow our step-by-step guide to setting up your own router
where it’s says
broadband password: you'll need the login details or the password that came with your EE router
I want to know if that means the WiFi password the admin login or my ee webpage login it’s not very clear to me which password it refers to
No it is not the wifi password - that is only for wifi on that router.
Your broadband username and password will be PRODUCTIONXXXXYYYYY.fs and the section describes how the password follows.
But when I login to my EE router it says my broadband name is readytoconnect@fs
I have no information about PRODUCTIONXXXXYYYYY.fs what are the x and ys meant to be?
cheers
Is your service live yet?
I understood the readytoconnect changed once the router went live, but maybe that is just on ADSL/.
Yes its live Im connected with the EE router atm and its settings are as follows.
Product code:Smart Router DX
Serial number:+EEH002+2046003931
Firmware version:v0.04.01.05202-EE
Firmware updated:unknown
Board version:R01
GUI version:1.1 28_11_2019
DSL uptime:5 days,04 Hours55 Mins31 Secs
Data rate:49.065 Mbps / 329.075 Mbps
Maximum data rate:77.801 Mbps / 458.348 Mbps
Noise margin:11.6 / 10.6
Line attenuation:0.0 / 39.7
Signal attenuation:0.0 / 39.7
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:3.7 GB Uploaded / 119.5 GB Downloaded
Broadband username:readytoconnect@fs
2.4 GHz wireless network name:EE-QCA1X8
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:EE-QCA1X8
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:60:8D:26:23:85:98
Software variant:-
Boot loader:0.1.7-EE (Fri Sep 20 18:43:31 2019
