close
Using a Vigor 166 G.fast modem with EE Fibre max 300
Thomas1979
I have just bought a Vigor 166 G.Fast Modem to use with my WiFi 6 router and EE Fibre max 300 connection.
My broadband username is readytoconnect@fs
The guide says for the broadband password "you'll need the login details or the password that came with your EE router"
My question is does that mean the Wireless password/key or Admin password or something else? I do not have any other passwords other than my EE login to web account?
Any help gratefully received.
13 REPLIES 13
AH just found my username in advancedsettings>>broadband
Thanks for your help, should have what I need now
No worries, glad I could help, let us know how you get on when you get set up on Tuesday.
As a matter of explanation :
The BB Username & pwd are for connecting to the EE network & being authenticated to be able to go on the Net. They are independent of the WiFi pwd/key & of the router's admin pwd which serve completely separate purposes.
Your BB Username is not "readytoconnect@fs". That's just the initial factory-set value until your EE router makes a full connection with BB & is authenticated thro' the EE network. After which it is fully populated with your true BB Username which you will now find  on the Advanced Settings/ Technical Log/ Information page, Your BB Username is of the form "PRODUCTIONHQNUN123456@fs".
Worked first time no issues, broadband speed is a tad faster than the EE smart hub and wifi is exceptional using an Asus rt-ax92u WiFi6 router recommend!
