close
New Phone doesn't have the same data on the plan
TheM4rshmellow
So, I recently upgraded from the Galaxy S8 to the Google Pixel 5. I upgraded to a 40GB data plan on the new phone.
On the phone itself however, it states I only have 2GB of data available to use, and I can no longer use this even though I have only used 1.25GB.
Would anyone have any idea how this has happened, and how to fix it? I've never seen a problem like this. On my EE account it states ove got 39GB left, so I don't know what the problem is
You sure you are not looking at the phone's own data usage limit, which you can change, probably under Mobile Data? That's nowt to do with your EE data allowance.
I have set no limiters or warnings on my device. I don't know what is causing it
Hi @TheM4rshmellow
I hope you're well and having a nice weekend, other than this issue of course.
If you're app says you have 39Gb of data then you should be good to go. Can I clarify can you connect to data at all?
Yes, I could connect to data, but now my data isn't working. I have tried adding and removing limiters, data warning, changing the date that the data refreshes on my mobile. Nothing works. Not sure what is wrong
@TheM4rshmellow This is a bit of a tricky on for sure.
I would suggest speaking with our customer care team so they can look into this with you.
