close
My internet speed goes down when I try and use anything that requires internet.
warhawk404
My internet started working on 13th April. Haven't had a problem till now, where when I try and play a game or do anything else that requires internet, it goes dowwwwwn. Like 27 mbps to 4 mbps kind of down, and sometimes even more. I get great signals and connectivity too. I have also tried restarting and factory resetting. Nothing has worked... why?
Which router you running through?
I am running a Smart Hub router.
Hi @warhawk404,
Welcome to the community 🙂
I would recommend calling our Technical Care Team.
They will be able to check your speed and connectivity on your account.
Alex 🙂
@warhawk404 : Welcome to EE's Home Broadband Forum.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
