on 26-12-2021 05:47 PM
I have an EE 5Gee router, I would like to use it as a bridge, my idea is to disable Nat and dhcp and turn on my Asus Router and connect via PPPoe, the problem is that I don't know the username and password, how can I know my Internet username and password?
on 26-12-2021 07:37 PM
Username: eesecure
Password: secure
on 26-12-2021 08:05 PM
Hi @Andrezinho1980 ,
As far as I understand it, authenticating using PPPoE as above is nonsensical as a physical link must first be established before there is any Ethernet present.
The best starting point is probably the below link. The alternative would be sending codes to the modem to establish a physical link. I would highly recommend to start with a device intended to connect with a cellular network.
If your upstream router does not support bridge mode, IP pass-through should be a good alternative.
https://draytek.co.uk/support/guides/kb-ltewanconfig
on 26-12-2021 09:30 PM
I'm going to try it tomorrow, the problem is that this 5g router from EE is really bad, I connected my mesh system to Deco S4 and it just doesn't work, sometimes it works, but it's very unstable, my Ring doorbell is another problem, it works 1 week and it doesn't work for 2 days, I would like to use this EE router just as a Moden and use my Asus Router to do the routing, I have another big problem which is port forwarding, as it is impossible due to EE using CGNAT and I don't have a public IP, I'm thinking about canceling the EE due to these limitations.
Thanks for answering
