close
WIfi mini
Marts2
My Wi-Fi mini has one a blue light flashing indicating that theres a message
went online putting the 8 digit number into my browser, and the Wi-Fi mini page loads up but to read text message i need to use a password tried all passwords that i can use for my EE account etc but none of them work.
Hi
After being on the phone to EE and going through the passwords with agent it could be, and still not working, I finally took the battery  cover off  and reset the device using the device reset button and then used the Special password printed under the lid of the device and that worked. so thank you.
@Marts2  Try “admin” as the passcode.
What 8 digit number? Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover.
Hi
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
