close
How to my wifi at home
Landshark2021
 Were Can i get my wifi code for my router
Had it on card frm ee but its rubbed off
Which router is it?
mikeliuk
Hi @Landshark2021 ,
You should be able to use online guides to access the management page to either check the current password or change it to a preferred new value.
https://deviceguides.ee.co.uk/
Mustrum
@mikeliuk  that will help if the OP still has the admin password which is printed on the same card as the wifi password - but if that roo has rubbed off, then it may require a call to CS for a new router.
@Mustrum : Not necessarily! The router could be so old that the admin pwd printed on & rubbed off of the label could well be "admin". However OP has not seen fit to tell us which router.
