close
Re: Topped up mobile broadband but have no data
Crofter10
This does not work!. Tried using it to top up and got message saying I need to turn off WiFI. If I turn off Wi Fi I lose the internet, Very clever EE
Leanne_T
Hi @Crofter10
Did you use this link My EE - Anonymous Top up?
Thanks.
Crofter10
The pages from EE tell me that I have to "turn off wifi" and then continue. But if I do that I cannot access the internet. Not very clever!
Crofter10
I may well be joining you in moving. It is actually easier to use non EE websites to top up!
@Crofter10 : It really means disconnect from your fixed BB router. You still need to connect by WiFi to your mobile router. What it's getting at is to come off your fixed BB & go to connecting by SIM. It's stupid mobile-centric EE mixing up WiFi with BB.
That link does not top you up but lets you buy more data with whatever credit you have. To top-up that credit 1st use the link @Leanne_T gave you.
James_B
EE Community Manager
Hi @Crofter10,
add-on.ee.co.uk/purchase is zero rated so you can always access it over mobile data.
Hope this helps.
