close
Keeps coming up that I can't establish a secure connection
cherishedchar
15 REPLIES 15
cherishedchar
Northerner
Hi @cherishedchar
  • What device do you have?
  • What are you trying to do?
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
James_B
EE Community Manager
Hi @cherishedchar,
Thanks for visiting the EE Community. Smiley Happy
Are you having problems with My EE via the app or your web browser?
I have a Samsung ace 4  and trying to go online
Sent from Yahoo Mail on Android
@cherishedchar
Install Google Chrome from the play store and use that rather than the stock Android browser as that was a bug.
You can also try:
  • Making sure the security policy/certificate is updated
  • The OS is updated
  • Any Samsung apps are updated via forget Samsung store in your phone's (not play)
  • You have the correct Internet settings.
Profile closed
Not applicable
I am also having the same issue. It started when I upgraded my current EE plan. Please help. No point of me staying with EE if my 4G doesn't work.
Please let me how to fix this?
Christopher_G
Hi @Profile closed
Welcome to the community.
Does @Northerner's advice above help you get a connection?
Do your other apps work OK?
No connection
Christopher_G
Hi @cherishedchar
Have you had this same problem since July?
