17-12-2021 10:35 AM
Yesterday I received this text message from EE:
"Great news! We've updated some of your network settings, please restart your phone to make sure it's up to date"
After restarting the phone (Pixel 5 on Android 12), the Google Weather widget displayed the message "Location permission needed."
I have checked the Permissions settings for the Google app and Location is set to "Allow all the time" and "Use precise location" is turned on. These are the settings that the widget should require.
Has anyone else had similar problems or ideas on how to fix the problem?
17-12-2021 11:23 AM
Hi @Wightknight
Are you still getting this message after checking your settings?
If so, have you tried turning location services off and back on again?
Thanks 🙂
17-12-2021 11:37 AM
I get similar issues following a reboot. I suspect the phone is still processing its permissions as widgets start and it just hasn't finished rebooting when the app requests location permission. causing the warning. They usually go away fairly quickly.
17-12-2021 02:34 PM
Hi Leanne,
Yes, I tried that. I turned location services off, restarted the phone and then turned them back on.
It didn't change anything. The problem still exists
17-12-2021 02:35 PM
Thanks for your comment.
I had left the phone overnight and the problem still persists.
17-12-2021 02:44 PM
Hi @Wightknight ,
Does GPS work ok with the Google Maps app which might suggest the issue is specific to this widget?
