close
Data usage
KTaw
How can i view the data usage of each of the three phones linked to my data allowance? The main phone currently has nhs unlimited data, but I pay for 100gb so this is currently shared between the two other phones. I would like to know the data usage split between these phones.  I have tried using the add-on link which used to show the individual usage, but this just displays the usage from May - not current month.
EssexBoyEE
If you use http://add-on.ee.co.uk/status on each phone it should give you a picture of data used and what's left up to today, on your Unlimited Plan though it won't tell you much, other than unlimited despite what you have used or gifted
If you gift from the UL to the other Phones it will also tell you what's going on in the EE App / Family Usage / See All.                .......when it works.
Thanks, I checked each phone, and it showed individual usage. But couldnt find the “family usage” area on the app🤷‍♀️
Thanks for your help👍
Here's a Screen Shot of the App on mine (Android)
Family usage bottom left, picture may take a while to appear it's it needs approval
