2nd Sim for Maxview Roam
Scrolin
I have just bought a caravan fitted with a 4G Maxview Roam. I would like to fit a 2nd Sim that calls off from the data allowance in my existing contract. 'Gifting' to a PAYG sim goes someway to achieve this but has the disadvantage that the 'gift' needs to be repeated every month and usage levels must be predicted in advance each time.
I can find nothing on the EE site that provides the full functionality I require.
@Scrolin  You can’t gift data to or from PAYG  you can only gift data to other contract sims on your account.
And you can only manually gift data when it’s needed.
'Gifting' to a PAYG sim goes nowhere! It isn't done on EE.
Gifting to a 2nd contract SIM on the same a/c is allowed.
Even further away from what I require then. I neither need nor want a 2nd contract, I'm quite happy with the one I have thank you.
Please always use the reply to address *******@**********, especially when saving to your address book. You will then not lose contact should I change email provider.
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
URGENT: Remove your email addy from this public site. You wanna be scammed? No one reputable from here will be emailing you.
No one will contact you from this user discussion group other than thro' the medium of these forums by posts such as this.
