Use WiFi Enhancer to get the best from your connection
JordanTA
EE Knowledge Specialist
Activate Work Mode or Game Mode within WiFi Enhancer to prioritise online traffic to those activities and get the best from your connection.
Sometimes, you need your WiFi to help you get more done, or to help you have more fun. Getting the most from your broadband just makes life better.
What is it?
That’s why we’ve created WiFi Enhancer. Activating Work Mode or Game Mode puts the power of your WiFi firmly in your hands. By automatically detecting and prioritising specific online traffic, it boosts your WiFi for working from home and gaming, so you get the best from your connection.
Work Mode
Work Mode optimises your broadband end to end, for working from home. Prioritise online traffic when you’re using apps like Zoom or Teams for those vital work calls.
Game Mode
Game Mode turbocharges your gaming experience prioritising your consoles and apps. It helps take your gaming connection to the next level.
You can switch modes on and off quickly and easily via the EE App, and it means you can be sure you’re getting the very best from your connection.
Geo Filter chooses the highest quality servers and blocks any that are laggy. It means lag won't get in the way of winning.
And you’ll also enjoy a fine-tuned connection thanks to Ping Optimiser—a proactive bit of tech magic that curbs buffering.
How do I select a mode?
Selecting a mode is simple, too—just head to WiFi Controls in the EE app and click on WiFi Enhancer to get started. Want to optimise for gaming and work at the same time? No problem, both modes can be used alongside each other.
Find out more by visiting our learn page
