Ee blacklisted my o2 phone by mistake
Essexdave1979
Right I am not and have never been a ee customer. I am with o2. I have a s24 ultra and was told its been blocked by ee. I contacted someone yesterday and sent them in my documents to show I am the owner of this phone and I got it from o2. Was told there was probably a mistake and a number entered wrong when someone lost there phone. They removed the blacklist for my but my phone is still not working. I just been on the phone and they have said the imei is no longer blacklisted and could take up to 24hiurs to remove. It's been well over this. Can someone help me pls
Christopher_G
Hi @Essexdave1979
Welcome to the community.
If it has been over 24 hours, our customer support team will be able to escalate it further, if you get back in touch with them.
I hope it's sorted soon for you.
Christopher_G
Hi @Essexdave1979
@Essexdave1979  Have you restarted the device ?  Have you checked to make sure your sim is still working ?  This needs to be put in a different phone to test this.
Been in touch with them. They added back to blacklist and removed again. Let's see if that helps.
Been restarting phone all day. Even reset it. And yes my sim is working fine. I am using another phone
Ali_A
@Essexdave1979
Have you been able to check with your own mobile network to see if it still shows a blacklist on your phone?
Ali
