HD Channels stream from a different region and it's driving me nuts!
NW999
Hi - I live in Chester. When tuning my TV channels I select Liverpool as my region. However, my HD BBC channels stream from Wales so I miss out on local news. Non HD channels stream BBC North West.
Phil9000
It sounds like you’re using a pro box in aerial mode rather than the “Freeview over broadband”/internet mode.
Freeview channels broadcast on different frequencies/multiplexes, which accounts for the difference.
For the multiplex which carries the HD channels it sounds like the signal is substantially stronger from the North Wales transmitter.
Do the correct region of HD channels appear in the 800s range of channels? Your channels from the North West/Winter Hill transmitter may appear here.
In some areas you might get a secondary region in internet mode. Extra regions will appear in the 800s range in this instance too.
Popebris
I had a similar problem,  selected London but got bbc south east and itv meridian.  Tried umpteen retunes at different times and different weather conditions.  Unplugged the box for 5 minutes then did a retune and finally got London HD channels.
Peter_W
Welcome to the Community, @Popebris.
Thanks for sharing your experience here 😊
Peter
