TV guide freeze
snes
Just interested to see if anyone else experienced this? TV guide froze on Tuesday - wouldn’t respond to any inputs. Rest of BoxPro functioned normally.
Didn’t respond to hard reboot, took a factory reset to restore normality.
There was a big update on Monday - wondered if there was a connection - hence, I guess, this post.
zulu17
Problem solver
Problem solver
These sort of problems with new releases should be fed back,
Christopher_G
Hi @snes
That does sound like it could have been a bit of a glitch. Would be interesting to see if anyone else had a similar issue around that date/time.
graybag
Yes,exactly same thing happened to me,could not move through the TV Guide  at all.After I updated Software (didn't need to re-Boot) could move normally  again because the Updates had changed the Guide re the "Improvements" (FAR worse than before!).
zulu17
Problem solver
Problem solver
