Sports channels
Thomas0909
How do you get premier sports on EE tv
zulu17
Problem solver
Problem solver
EETV doesn’t offer Premier Sports currently.
So you would need to take a subscription direct with Premier Sports  or possibly if you currently have Prime Video subscription sign up to their Prime Video  (Premier Sports  video channel subscription).
EETV Box Pro and Box Mini don’t have Premier Sports app but do have Prime Video app.
EE TV (Apple) box should have Premier Sports app able to be installed from the App Store.
11 REPLIES 11
zulu17
Problem solver
Problem solver
Richardr66
Expert Contributor
Expert Contributor
Are you certain that the Apple TV box has the Premier Sports player? I couldn't see it on there. Some TVs such as the LG I have have it, and Amazon Fire / Android TV (which as well as google includes recent Sony, Phillips and Panasonic TVs) both have it. I couldn't see it on the app store on my Apple TV.
Yes and Amazon will charge you £15.99 per month  i have a live subscription with preiersports and  can't  get it on EE tv.  Does anyone know how I  can do it as I can get it cheaper buying direct from Premiersports.  Appreciate any suggestions
zulu17
Problem solver
Problem solver
@Magsy1  If you check Premier  Sports own website I believe you can subscribe to an annual subscription  , 12×monthly  or full year up front that would bring your price down but with less flexibility  as to when to cancel  (always check when these auturenew).
@Thomas0909  looks like  not on Apple TV box from available  documentation.  Perhaps  airplay or casting possible  ?
@Magsy1
Try a cheap Android device from Amazon like the X96Max+, £35 or so. You should be able to download the Premiersports app from Google Play to one of these, and watch that way.
Should…. But if it doesn’t work, Amazon’s returns policies are very good.
Thanks Midnight-Voice will give it a go, will let you know how it goes
I’m in same position and would be good to know how you get on
I will definitely let you know
I purchased the X96 Max box from Amazon it cost £35 uploaded it to my network and my husband can now see his Sports.  I found this box not user friendly freezes and poorinstruction on what buttons on the remote are for.  It was a bit of trial and error took a lot of patience but eventually downloaded the app.  You could also view Premier straight from the internet which maybe better, but I wanted an app as it is easier fom hubby to use.  I am sending this box back, I looked up google and (how did we live without him) and looked for the best android devices it came up with Nvidia Shield at £188.98  or the Amazon Firestick 4 at £69.99 I think the cheaper ones work as well.  Here is the link to what it says about them
https://www.bestproductsreviews.co.uk/streaming-tv-box?targetid=dsa-100259827750&matchtype=&device=c...
https://uk.pcmag.com/media-hubs-receivers/9559/the-best-media-streaming-devices
Thanks to everyone who responded and helped me out.
