29-09-2026 10:00 PM
Sorry to resurrect this, but has something changed with the watermarking recently?
I’m still new to EE but Tonight I’ve noticed the small white circle/dot watermark on Sky One, Sky Sci-Fi and Sky Atlantic when watching the integrated channels through my EE TV box.
I don’t recall it being present previously. Interestingly, if I switch to the NOW app on the same EE box and watch Sky Atlantic live, the watermark isn’t there.
I saw a previous post saying the watermark had been removed from most entertainment channels following discussions with Sky. Has there been a recent change, or is this possibly a fault?
thanks.
30-09-2026 10:57 AM
Confirmed - it's only enabled on channels that Sky require us to have it on (their premium content). Nothing has been changed.
30-09-2026 09:34 AM
Thanks for the notification @AsaintUK - the team are investigating. You're right that it was removed before, but they're checking whether anything has contractually changed to require it to be added again, or if it's just a configuration error.
30-09-2026 10:37 AM
Its on some of the Sky channels its an anti piracy measure to combat uploading of the content to the internet its on some sky channels but not the movie channels, its also a licensing watermark on the EE guide sky channels , you wont see it on the Now app as Now is owned by Sky.
Check the Ai answer it will explain it all nothing is broken.
30-09-2026 10:57 AM
07-10-2026 12:03 PM
Just to clarify, I have it on all sky ones, sky one, sky Atlantic, sky sci-fi, I thought it was removed from all of these,
quite annoying as my eye is drawn to it, I know i can use the now app, just an an extra step I wasn’t expecting.
Thanks for your help though.
07-10-2026 12:08 PM
It was removed from the less important channels, but all those you've mentioned are classes as premium content and are specifically mentioned in the requirements from Sky.
