| For up-to-date information and comments, search the EE Community or start a new topic. |
26-12-2018 07:22 PM
I cannot connect to EE WIFI auto underground. When I try connect, it asks for username and password which doesn’t work. I had a reset from 9527. I tried to access via virgin media WiFi chosing EE but I get an error message saying contact customer service.
Help?
01-01-2019 09:23 PM
Hi, I have a Zenfone 5z on Oreo 8.0. Bought 2 weeks ago an ee payg sim, topped it up with 10£ on 31 dec. Yet I still can't connect to EE wifi-auto. I checked and EAP method is on SIM. Any suggestions?
02-01-2019 08:03 AM
Good Morning @Robzzilla.
Welcome to the community.
Are you getting any sort of error message when you're trying to connect?
Jon
02-01-2019 09:11 AM
Good morning @Jon_K
It tries to connect over and over again without success, sometimes it says that it's disconnected
02-01-2019 09:44 AM
02-01-2019 09:55 AM
Yes, I've done that many times but with no luck, after a while it states that Authentication failed 😞
02-01-2019 10:31 AM
I see @Robzzilla.
I'd recommend contacting our technical support team so they can have a look at your account and make sure everything is set up correctly.
Let me know how you get on.
Jon
02-01-2019 11:56 AM
Thanks for your support and time @Jon_K , I forgot to mention that I have 2 sim cards in my device:
1st ee with data, 2nd is orange in ee roaming with only voice and texts allowed. Might this affect my wifi connection. I will remove the 2nd and try it again in the tube station.
02-01-2019 12:06 PM
It's certainly worth a try @Robzzilla.
Let us know if this works when you manage to give it a try!
Jon
03-01-2019 08:55 PM
So I contacted Customer support and they fixed this issue the second day. Now I can connect to EE Wifi without issues
04-01-2019 07:47 AM - edited 04-01-2019 07:47 AM
Brilliant news, @Robzzilla. 🙂
Glad you managed to get sorted.
Do you know what they did to fix it?
