Cannot connect to EE WiFi auto
Sniti11
I cannot connect to EE WIFI auto underground. When I try connect, it asks for username and password which doesn’t work. I had a reset from 9527. I tried to access via virgin media WiFi chosing EE but I get an error message saying contact customer service.
Help?
46 REPLIES 46
Hi Chris
I'm afraid that didnt work! Still no luck connecting on tube.
thanks
Christopher_G
Thanks for trying, @Nadia88
I've sent you a private message to get some more information from you.
Please have a look and get back to me.
Thanks 🙂
Asanteman
I have a Xiaomi 10 and I cannot log in to ee auto WiFi on the underground.
It keeps asking for username and password.
I have tried reset number and no luck.
Help?
James_B
EE Community Manager
Hi @Asanteman,
Are you using a pay as you go or pay monthly plan?
I've got a similar problem. When I text EEWIFI to 9572, the message just doesn't go through.
I have topped up £10 in the past month, and all other texts work fine.
James_B
Hi @urban4692,
What type of phone are you using?
Are you on a pay monthly or pay as you go plan?
Hi James, thank you. It's an iPhone 12 on PAYG.
James_B
Hi @urban4692,
iOS devices should connect to EE WiFi automatically, there's no need to set it up via text.
Have you topped up with at least £5 in the last 30 days?
Hi James, yes I know it should connect automatically. When I click on EE Wifi Auto is says "can not connect to network".
And yes, I topped up £10 two weeks ago.
James_B
Hi @urban4692,
Do you only have this issue at one particular underground station or everywhere?
