05-08-2021 07:12 PM
Good evening so I have just changed too EE broadband from BT, now my problem is I have a g fast faceplate from bt on the master socket and it doesn't seem to allow to hub to connect to the Internet, I have bought a new one and it still the same, when I remove the faceplate and plug straight into the wall it works perfect, has anyone else had this issue?
07-08-2021 12:23 PM
@pip11 you are still wrong, not just Business Hubs - where is you evidence?
Use a BT Hub 2, 3, 4 or 5 on a Plusnet connection - Plusnet Community
bt home hub 5 on plusnet - Google Search
07-08-2021 12:37 PM
BT Hubs & probably PN Hubs cannot be used on EE BB not cuz of the length of the BB Username but cuz they won't accept the '@fs' at the end of it.
07-08-2021 01:03 PM
Mustrum I am sorry but you come across as a very negative person and a bit of a know it all why don't you give people a chance it's not your job to jump down everyone's throat I have been on this one day and noticed it I don't want to fall out with you you might not even know you are doing it sorry.
07-08-2021 01:08 PM
@WhiteRabbit1 : How do you make that out? @Mustrum is entitled to his opinion. This is just a difference of opinion on a forum. Nothing new!
08-08-2021 12:21 PM
So I have tried the g fast faceplate and the 5c faceplate, both don't work, removing them and plugging directly into the socket with a micro filter it works perfect, everything worked as it should with bt and g fast faceplate but not with ee.
08-08-2021 01:07 PM - edited 08-08-2021 03:54 PM
Hi @Kevdh ,
Are you able to tell A. which step of the connection process fails for the EE router when connected to the faceplate as compared to when connected with the test socket?
Presumably it must fail earlier than authentication as I would guess the credentials are correct as proved by connecting to the test socket so authentication cannot fail connected to the faceplate (if it reaches that stage).
Due to the failure of two faceplates, if you still have your old BT router, I feel that the only further information to be gained will be to see if the BT router fails differently when connected to the faceplate versus the test socket.
From the above thread, the BT router must fail authentication by the test socket and you will see this by visiting any webpage and getting an error page. They key test would be B. if the BT router behaves any differently connected to the faceplate.
There are two cases: 1. the BT router fails earlier than authentication which confirms the behaviour of the EE router; or 2. the BT router proceeds further than the EE router and fails at the authentication step (visit to any webpage gives an error page) which matches the behaviour of the BT router connected to the test socket.
I feel your input to points A. and B. above could help to progress the debugging. You may not be able to address B. if you have returned your router, so perhaps order a compatible router online for testing.
In the above, I'm assuming you have nothing else wired to the faceplate, have not tampered with the faceplate, and a visual inspect of the connections suggest the faceplate is not obviously physically defective.
08-08-2021 01:56 PM
Compare the router's Technical logs with & w/out a faceplate.
08-08-2021 07:33 PM
@MustrumI'm quite happy to hold my hand up and say I was wrong. Pity you didn't lead with that post link rather than to a business hub one.
