Broadband Speed
Cheeser
Hi, I should be getting a minimum of 31Mbps but I only recieve around 20Mbps on a wired speed test on a freshly restarted router. Is there any way to fix this? Working from home is difficult, especially when it drops below this.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Mustrum
Your speeds are certainly much lower than they should be, and getting worse.
Are you able to listed to the phone line, dial 17070 option 2 - is it quiet?
The next step would be to locate the Master Socket, remove the front cover to reveal the test socket, you will need a dangly filter if you are not already using one, and repeat the modem stats and post here.
If it were me I would be in touch with the Broadband support team, get a fault reported, but also ask about moving to FTTP - the WBC FTTP on the BTW line check. You would get a more reliable and oif you want faster service.
Something's well preventing you from getting your expected speeds. Could be noise! Follow @Mustrum 's advice for testing for it.
What are all EE's estimated speeds which you'll find in your MyEE for BB under "Your BB speed"?
You shouldn't need to move to faster more expensive FTTP just to overcome a fault.
