unlock ee sim card,
Budgie65
does anyone know how to unlock ee sim carrd the ee  sim service isnt working
6 REPLIES 6
@Budgie65  If the device is asking for the sim pin and you haven’t changed this to your own PIN number the default sim pin is 1111.
no such  luck here
@Budgie65  Is the device asking for the sim pin ?
Budgie65
yes it is annoying
Budgie65
ve tried ee   free unlock gives me a side then shuts
Christopher_G
Hi @Budgie65
AS @Chris_B said, the default SIM PIN should be 1111, unless it has been changed at some point. How many times have you tried to enter it? A few incorrect attempts should prompt you to enter a PUK code, which can be found in your EE Online account. Once that is entered, it would allow you to change the PIN again.
