PAC CODE REVERSE
AUSTINSHABBA
I accidentally made a switch to a different provider last night, Plan.Com (Presetige) and used the PAC Code to transfer the numbers over to the new contract. However, after realising what I had done, I no longer want the transfer to happen and want to stay with EE for all 3 lines.
I have asked the new provider to cancel/delete tthe PAC from their end but all I'm getting is "we are a business connector with EE, so you still with EE" but essentially I'm not.
How can I stop this?
James_B
EE Community Manager
Hi @AUSTINSHABBA,
I'd recommend raising a complaint with the retailer to escalate your issue.
20 REPLIES 20
Katie_J
Hello @AUSTINSHABBA
The new provider will need to cancel the port request on their end I believe.
Have you spoke with our customer care team to see if they can stop this?
Katie
A PAC is used to transfer an active mobile number to a new operator.
If you're remaining with EE, this is not what a PAC is for. I agree that once a PAC has been used, it needs to be either cancelled from the recipient end, or a new PAC issued to port back.
Yes, I did online. They said the same as you.
However, the new provider say they can't do it either because it's a business contract and there's no cooling off period. But then someone else says I remain with EE and to ignore the swapping terms. So I'm confused.
I need help. Is Plan.Com partners of EE?
I'm in limbo here because EE can't delete it their end and I have no way of doing it my end. The new provider is being difficult
James_B
Hi @AUSTINSHABBA,
If you placed your order online, you'll have a 14 day cooling off period.
Hope this helps.
It was over the phone from a mobile number. They say there is no cooling off period for a business contract, I didn't even want it for a business purpose. We're residential
James_B
Hi @AUSTINSHABBA,
If you ordered over the phone, you should still have the 14 day cooling off period.
They insist I don't.
What can I do?
Stevie- Austins wife
James_B
Hi @AUSTINSHABBA,
