URGENT!! Glebe Farm milton keynes no signal
Elvis079
Valued Contributor
Valued Contributor
Since my ex and kids move to Glebe Farm in Milton Keynes.
..  Nearly a year ago..There is no signal at all.. Inside or outside.. No way to answer a call or use mobile data..
I was reporting it to EE by chat and by phone months ago..And nothing happens..
I know that I can use wifi calling.  But.. Really?
It is really annoying..
Never have issues with signal.. Except there..
Make it work.. EE
22 REPLIES 22
Elvis079
Valued Contributor
Valued Contributor
I just tried to call technical support..
I just tired and annoyed by these automatic responses
Please stoop send me these links as I tried them to many times..
I trying to report an issue for months now.. this is really frustrating..
James_B
EE Community Manager
What problems did you have when you tried to call Technical Support @Elvis079?
Elvis079
Valued Contributor
Valued Contributor
My problem is with a network and thats why I am here.. Because technical support website was useless..
If you are not able to help me. Just tell me..
Don't send me these links as I tired of trying them..
James_B
Hi @Elvis079,
It was a link to our contact page I was sharing to help you get in touch with our Technical Support Team who can help you.
You can dial them directly from your EE phone on 150.
Are other EE users equally experiencing poor coverage in this location?
You've alluded to having a 5G phone, is there any difference to service if you disable 5G or force 4G - depending on your device's menu options. This is a good test of whether fringe coverage is the problem.
Elvis079
Valued Contributor
Valued Contributor
I tried everything.. There is no coverage in this area
I was trying my simcard in thee different phones..
This area has no EE coverage... O2 for example working fine.. On the same phones.. As I said.. No signal reception in there.. And EE does nothing about it..
Mustrum
@Elvis079   HAve you tried the Ofcom coverage checker?
https://www.ofcom.org.uk/phones-telecoms-and-internet/advice-for-consumers/advice/ofcom-checker
Not sure of your postcode, but I tried
MK17 8XU seems EE and Three have no coverage.
@Elvis079 wrote:
This area has no EE coverage... .. No signal reception in there.. And EE does nothing about it..
If this is a poor coverage area, then often the only solution is to build a new network site.
Elvis079
Valued Contributor
Valued Contributor
I know there is no coverage in the area.. I am here very often i tried
everything.. That's why I place this post here..
Hoping that EE will do something about it..
But they done nothing for last six months..
And this is not my postcode..
Elvis079
Valued Contributor
Valued Contributor
Thats my point.. And idea of this post.. They need to do some improvements
here..
