EE signals in Milton Keynes ...
Zeeshh
Recently moves to Milton Keynes and disappointed to see the poor EE signals in almost every corner of Milton Keynes. Especially in Glebe Farm. Seemsblike Milton Keynes is not a priority for EE ??
Northerner
Hi @Zeeshh
Have you checked EE network status checker:
https://ee.co.uk/help/service-status
Can you explain what you mean by poor signal.
Hi Northerner,
There's no signals in Glebe Farm are post code MK17 8xx, and very poor signals in most of the Milton Keynes areas and data connectivity is worst as well.
MK17 8xx post codes are less than 1 mile from M1 motorway and series of large warehouses of big names.  I was expecting much better signal quality and data connectivity here.
It's a good sized city and with loads of big businesses but seems like EE doesn't have enough towers or capacity here. Any plans EE shall install new towers etc ?
The Glebe Farm area does look to be an area of poor indoor coverage, and some of the buildings there have indoor coverage solutions. Outdoor coverage shouldn't be an issue though.
Yeah but how to escalate to EE to fix the issue ?
In the first instance, always use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker and then "report a problem" if there seems something significantly wrong compared with normal.
