URGENT!! Glebe Farm milton keynes no signal
Elvis079
Valued Contributor
Valued Contributor
Since my ex and kids move to Glebe Farm in Milton Keynes.
..  Nearly a year ago..There is no signal at all.. Inside or outside.. No way to answer a call or use mobile data..
I was reporting it to EE by chat and by phone months ago..And nothing happens..
I know that I can use wifi calling.  But.. Really?
It is really annoying..
Never have issues with signal.. Except there..
Make it work.. EE
22 REPLIES 22
James_B
EE Community Manager
Hi @Elvis079,
What does the Coverage Checker report for the location?
Elvis079
Valued Contributor
Valued Contributor
Postcode is not recognise by that website.. So it is hard to say..
James_B
Hi @Elvis079,
Is it a newly built property?
Are you entering the postcode in the correct format, including a space between the two parts of the code?
Elvis079
Valued Contributor
Valued Contributor
It is a new build.. And yes I put the post code correctly
Weird thing is that just 2 minutes walk and  i have strong 5G signal..
James_B
Hi @Elvis079,
It can take a little time for new postcodes to be added to the database.
In the meantime, our Technical Support Team will be happy to take a detailed look at the coverage in your area if you get in touch.
Elvis079
Valued Contributor
Valued Contributor
I was in touch with them.. Few times.. Already..
They weren't able to find an address once..
The other time they put my issue on the map 5 miles away from the address I was complaining about..
I just want to be able to use my phone..  Not looking and walking around to get some bars on my screen..🙂
Elvis079
Valued Contributor
Valued Contributor
Little time? Yes..
But I reported it in September  last year..
James_B
Hi @Elvis079,
Our Technical Support Team will be able to locate your address manually to take a look at the coverage for you.
I'm sorry if they weren't able to find the right location the last time you called.
Elvis079
Valued Contributor
Valued Contributor
I post it here because technical support team  was unable to help me
