Mobile Network discussions
Discussion about mobile networks
Forum Posts
Stay connected if your data runs out
Knowing that you can keep in touch with friends and loved ones even if your data’s run out is one of those little things that just makes life better. That’s why Stay Connected Data comes included in our No Frills and Essentials plans. How it works St...
JordanTA by EE Knowledge Specialist
  • 2401 Views
  • 3 replies
  • 7 Helpful
EE Mobile Coverage and Service Status Checker
Check mobile coverage and ongoing maintenance in your area using the EE Mobile Coverage and Service Status Checker. "Check coverage" will predict the usual level of service, whereas "Check service status" will show known issues and faults. You don’t ...
Rach_H by EE Community Support Team
  • 1411 Views
  • 0 replies
  • 5 Helpful
SE25 continues to have bad connection
Hey EE Team,The area of SE25 continues to have bad Internet connection even tho EE said there was a new mast on air since March 6th. I am not nearly getting the same speeds as last year hovering around 0.2 to max 5 Mbits while your website says there...
cgotta by Visitor
  • 34 Views
  • 2 replies
  • 1 Helpful
Coverage in Bayswater
Update: 03 May 2024 For the first and third location (back-up in case of any unforeseen complications with the first two locations), we are building the new mast on the roof top of a high rise building. This will take longer than some of our other ne...
Leanne_T by EE Community Support Team
  • 12480 Views
  • 44 replies
  • 11 Helpful
Resolved! Loss of 5G coverage in NE4 9**
Similar to other recent posts, there’s a loss of 5G coverage in NE4 9** . 5G had been fine since it launched here but it disappeared about a week ago (4G only now on both EE phones in the house). Looking now,  your coverage checker says 5g isn’t avai...
ahad2 by Contributor
  • 930 Views
  • 26 replies
  • 7 Helpful
Coverage GU14 6EJ
I have had very little coverage now for over a week, and it’s becoming unacceptable.  I cannot speak to anyone and I’ve been with Orange /EE for 20 years!!
BlueGyps by Explorer
  • 69 Views
  • 3 replies
  • 1 Helpful
Why is the signal so bad in central London?
Can someone explain the technical reasons why I got better signal in central London in the 90s, than I do in 2025 on EE? I work near Oxford Street, and the signal is dire. Often it will show that I have good signal, and yet calls will drop, or web pa...
h29039f by Investigator
  • 333 Views
  • 14 replies
  • 4 Helpful
Coverage in Wednesbury
Update: 10 April 2025 Over the past few months, our engineers have been continuing negotiations with the site provider to agree the terms of the build and access the area to start building the equipment for the new mast. Once all negotiations with th...
  • 7171 Views
  • 64 replies
  • 27 Helpful
Satellite Messaging
Hi Team,Do you have plans to enable satellite messaging on the EE network?I know emergency SOS is currently enabled, but more countries are now rolling out sending sms by satellite.Of course I’m talking about iPhones here after the iOS 18.5 rollout....
Coverage status
Really disappointed with EE lately. Constant poor connection on both 4G and 5G — no or just one line signal bars but barely any data actually works. Coverage checker says the area has “excellent service4G and good on 5G,” but the reality is the compl...
