Loss of 5G coverage in NE4 9**
ahad2
Similar to other recent posts, there’s a loss of 5G coverage in NE4 9** . 5G had been fine since it launched here but it disappeared about a week ago (4G only now on both EE phones in the house).
Looking now,  your coverage checker says 5g isn’t available in my postcode yet ( it was) but after two reports on the service checker I’m told there is no problem.
I would call but don’t have the time to wait on hold in the evenings and can’t use my phone for calls when I’m at work during the day. The lack of detailed information is a little frustrating (e.g. is it a permanent change in coverage or something that can be fixed).
Both 4G & 5G services are delivered across combinations of multiple frequency bands, it's not unusual for there to be local amendments to the specific config. This can sometimes cause variations to the perceived coverage.
If the coverage checker has been amended, and now shows 4G rather than 5G coverage in your location, I would suspect this is now the service you should expect - at least until further rollout happens locally.
Having a pre & post analysis of the various carriers in use would be the only way to further advise.
26 REPLIES 26
ahad2
Thank you for the prompt and detailed response @bristolian, greatly appreciated.
If this is the case then it is disappointing (data speeds are inconsistent on 4G here - they can go from perfectly useable to every request timing out). I’ve previously been happy to pay the higher prices you get at EE because of the consistent coverage quality.
If this was a planned/scheduled network change, I suppose there’s nothing to be done. I can review when our contracts are up and decide what to do at that point.
whiskerp
Skilled Contributor
Skilled Contributor
Similar has happened in KT15 2. Perfect 5G until a few weeks ago and now only 4G. The coverage checker shows 5G coverage and lists no current fault but 5G has definitely disappeared. Surrounding towns still have 5G so it's not a phone problem.
Christopher_G
Hi @whiskerp
Did you report a problem on the status checker? That will flag it with our network team who'll look into it and update the checker if there's a problem.
rhysster974
similar to MK40 and MK41 postcodes. all of Bedford does not have 5G unless you are at the mast locations themsleves. I really do not know whats going on. Spoken to EE and online pnety of times and they do not have a clue and cant see any remedial work going on for this, However contractdictry to this spoke to someone in the EE shop and they said they are working on it . Its quite honestly a joke
whiskerp
Skilled Contributor
Skilled Contributor
It's not just one mast but the whole area has gone from NR-NSA override to 4G-CA. There are two classes of 5G on EE - if you have a Samsung phone, one has a solid 5G indicator and one where it's outlined. I wondering if they are upgrading the network in the area? But it would be nice if they knew what they were doing.
I have reported it via CS who say nothing is wrong which is absolutely not true.
Matt_124
The outlined indicator on a Samsung indicates that 5G-NSA is Available/present on neighbouring cells but you are not connected to it at that time, only 4G LTE.
When it is filled in, this indicates you are connected to a 5G NSA frequency band in addition to 4G LTE, or 5G SA where this is present.
Apps such as NetMonster report this outlined indicator as 5G NSA Disconnected.
rhysster974
Okay I wonder if this is the same in my area. MK41 8
